68 427 TI Coil Wires Connections - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    Gentlemen. Can you please conform that with a TI coil, the white cloth wire connects to the positive post on the coil and the black harness wire connects to the negitive post. Does it make a difference which post the condensor wire connects to? I looked at Dave Feidler's diagram, but don't see the condensor mentioned.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • John C.
    • January 1, 2005
    • 616
    Re: 68 427 TI Coil Wires Connections
    Jack
    Yes, the white cloth resistor wire connects to the positive post and the back wire to the negative. I don't know if it makes a difference or not, but on my car the condenser is attached to the negative post.
    John
    • Jack C.
      • 1090
      Thanks John. She fired right up.
      Jack Corso
