If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Can anyone tell me what this came on from the factory? I can't seem to find a date on it but it has an overflow outlet on it that seems to not be as reinforced as the later style. Thank you in advance for your time and knowledge.
Casting was originally used on '59 Chevy Truck with 283 and 60-67 Chevy Truck 283-327. Has 1/2 inch bypass fitting vs 3/4 fitting as used in other applications.
