Seat track with adjuster - GM#3913070 - NCRS Discussion Boards
  • Henry J.
    • November 1, 1999
    • 457
    I need to replace a seat track with adjuster on my 68. On my problematic one, it appears that the indentations between the latching teeth have worn to the point where the seat no longer remains securely in position, even with a new spring. Perhaps Bubba enjoyed too many 1/4 mile launches.
    As none of the regular parts catalogs indicate availability of this particular item, I will have to locate a good used one.
    I believe that the seat track I seek is GM#3913070. My question is this: for which model years after 68 was this track/adjuster used? My (limited) resources suggest up to and including 1971.
    Thank you for any help you can provide.
    • 43276
    Re: Seat track with adjuster - GM#3913070
    Henry------
    That's it. The GM #3913070 (and 3913069) were used from 1968 to 1971.
