Stuck nut on evaporator - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    While repairing the evaporator housing I had to remove the POA valve to get the whole thing apart. The nut on the evap. outlet is siezed to the tube, had to unscrew the POA valve from it to get it off. The nut's been soaked with Kroil each morning and evening for two weeks but it won't budge. Any ideas?? I'd hate to do any damage to the evap. Thanks!!!
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Re: Stuck nut on evaporator
    Lynn,
    Try CRC Freeze Off available in most auto parts stores. I sprayed steel studs in aluminum manifold once every 4~5 minutes 6 times in 30 minutes and they finally broke lose.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Clem Z.
      • January 1, 2006
      • 9427
      try some heat from a bernz a matic torch
