If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I have the original engine out of my '65 Coupe, probably for the first time ever. There are some chalk marks that I have found under 47 years of dirt and grease. These marks, in a yellow chalk read "d H". They are on both side of the block. Anyone know what these letters mean?
Thanks. Mike
Thanks. Mike
You know Mike, I don't suppose you need me to tell you what a feat that is to have the original finish on your engine. Congratulations and enjoy your Corvette.
Here are a couple of more photos. Doing all of this to move up the NCRS 2nd Floight to Top Flight (hopefully).[ATTACH=CONFIG]38915[/ATTACH][ATTACH=CONFIG]38916[/ATTACH]
I wonder why the pan gasket on the right side is actually a gasket for the left side? Note the configuration/loop for the dip stick.
