There are 3 hoses that comprise this setup besides the 3 hoses that connect the 3 carbs together. My question is: Does it make a difference which way the hoses are attached to second the tee? The hose coming off the smog pump should attach to the bottom of the tee (T) and the choke pulloff and carb vacuum to the other two legs (horizontal) of the tee. Would it make a difference in vacuum performance if the smog hose was connected to one of the legs first and not the down leg?
68 400Hsp 4 Spd with A.I.R vacuum hoses connection.
