My 65 convert has an electric choke as part of the Holley carb (not original). I running a Pertronix Electronic ignition so I'm not using the ballast resistor in the circuit. Holley doesn't recommend wiring across the coil (+) due to voltage drops. Any ideas as to where I can find a 12v keyed source so I can hookup my electric choke?
It doesn't seem that the extra prongs in my fuse block has anything that's a keyed 12 v.
![Confused](https://www.forums.ncrs.org/core/images/smilies/confused.png)
