If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Jerome, The fuse colors for your 72 , Red= 10AMP, White= 25AMP. The small dash lite fuse is brown=3AMP?, Clear= 20amp. hope thats right I am doing this from memory.
I think that member Pete Lindali sells color coded fuses.
I am pretty sure that super secret color code (I think the 3 amp = purple, but check to be sure because I too am working from memory) is in the 1970-72 TIM&JG, but don't tell any one or the secret will be out.
The TIM&JG could maybe be use some of this info to enhance the info already found therein.
The problem with putting too much information in the manual is worse than having not enough information. If we put that list in I could forward to you all the questions from people who would want ALL those pretty colors in their fuse panel. Trust me, I have been there; and recently too.
I understand, but the operative words are "some of the info" i.e. color = ampere. Not just a couple, but all applicable fuses with associated color and amperage.
The manual is well done and team that put it together did a great job.
Keep in mind that there were two suppliers of fuses each with their own interpretation of the specified colors, as well as different methods of color application.
Buss and littlefuse were our only sources. I do know each had a different process for applying the colors, resulting a slightly different appearance, but both were used interchangibly
I hate to spoil things for the color sensitive folks who posted earlier. My 71 does not have a 3 AMP fuse. It has a 5 AMP for the instrument lights. Is there a special color for 5 AMP fuses.????
