How did they drill/locate holes for TI amp in fendewell? - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5137
    I understand that this location varied some from one LT-1 to another. Anyone know what kind of tool/template they used? Just curious, since about 1 in 12 cars was LT-1.
    • 15596
    Re: How did they drill/locate holes for TI amp in fendewell?
    It could not have been much of a template because I have seen them anywhere from rubbing on the hood to so far outboard that the only way we could tell something was there was by braille. There must have been some kind of template to locate the three holes to each other, but beyond that I doubt there was anything. If there was, it was a major fail.
    • Terry L.
      • August 13, 2007
      • 99
      When I installed the TI amp on my fender skirt there was 3 dimples in the molding for locating drilled holes. It was a perfect match for mounting the amp. The dimples were located on the forward side of the fender skirt. The dimples were very minute and difficult to see.
        • 43213
        Terry------
        That's exactly how it was done. While not shown in the 1971 AIM, the use of the dimples to establish the correct location for drilling the mounting holes for the TI amplifier is shown in earlier C3 AIM's. The exact same procedure was used for 1971, the last year that TI was available in a Corvette.
        • Mike E.
          • February 28, 1975
          • 5137
          They certainly didn't pay any attention to the dimples---did they use some kind of three-headed drill to ensure spacing? A cant-miss template that ensured hole spacing but not location?????
          • Graeme B.
            • October 23, 2007
            • 213
            I've often wondered this. I know they were supposed to use the dimples to drill
            but how did they get the drill in there? A template on the back side would be easier.
            Cheers, Graeme.
              Cheers, Graeme.
              Graeme -
              Most of the assembly plant-drilled holes in the inner fenders were done before the inner fender was loaded into the front clip bonding fixture; that's also when the rubber splash shields were stapled to the inner fenders, and any brackets/reinforcements were riveted to the inner fender.
              • Mike E.
                • February 28, 1975
                • 5137
                John--
                Did they drill the holes indidually, or with a specifically designed and special-built tool?
                  Originally posted by Mike Ernst (211)
                  John--
                  Mike -
                  Typically, if dimples were present, they didn't use a fixture; otherwise, they used a simple fabricated aluminum apply fixture with steel drill bushings in it.
                    • 43213
                    Mike -
                    John------
                    That's how I would expect it, too. If dimples were present I can't imagine there would be any easier way to drill the holes, including a template.
                    As far as a "3 headed drill" being used that would seem very unlikely to me, especially to facilitate the installation of an option that was specified only on a minority of cars built.
                    However, the above is applicable to 1968-71 Corvettes which is the original subject of this thread. I don't know if dimples were present on 64-67 panels. If not, I would expect that some sort of template would have been used.
                    • Richard F.
                      • May 31, 1986
                      • 193
                      If I remember right using the dimples on a 69 I had would have caused the TI to be mounted right where a reinforcing bracket was located. The reinforcing bracket was added sometime during the 68-69 era.
                        • 43213
                        All------
                        Can anyone post a photo of the REAR of the panel to which the TI amplifier is attached on an original TI 1969-71 Corvette and showing at least the rear of the fasteners securing the amp to the panel?
                        • Graeme B.
                          • October 23, 2007
                          • 213
                          Joe ,I would like to see a photo too. I'm sure a lot weren't drilled before assembly and maybe some drilled that weren't supposed to be.
                          Cheers Graeme.
                          • Keith L.
                            • April 7, 2008
                            • 378
                            Is this what you mean?
                            • Graeme B.
                              • October 23, 2007
                              • 213
                              Thanks Keith, that's exactly what we mean.
                              My L71 was in that position but I was told it should go on the other side of the reinforcing bracket.
                              Cheers, Graeme.
