63-67 A/C Dehydrator (drier) identification - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    Re: 63-67 A/C Dehydrator (drier) identification
    I was asked to post these pictures from my dads June built 67 427/390 with factory AC
    • Bill C.
      • May 31, 1989
      • 424
      Keith,
      Great pics, thanks. That unit sure has the boss.
      Interesting, the long span between the end plate casting date of H-31-6 and the actual assembled date of 02-13-7 and finally making its way onto a car in late June.
      Bill Caldwell
      • Wayne M.
        • March 1, 1980
        • 6414
        Keith -- Thanks for posting these pics. It seems [based on your example] that by late '67 model year all of the "markers" are of the 2nd design (ie. clutch 3 square holes; crimped [not swaged case]; relief valve plated and with round hole; drier with square boss).
        Now, if only some souls will do the same for their known original 1966 model year compressor, as well as their dehydrator.
        • Jim S.
          • March 1, 1986
          • 1398
          Wayne,
          Here you go !
          Off my 66 20900 car.
          • Jim S.
            • March 1, 1986
            • 1398
            Originally posted by Jim Schwering (9598)
            Wayne,
            Here you go !
            And The Last one .
            Jim
            • Bill C.
              • May 31, 1989
              • 424
              Jim,
              Great pics! Thanks for the effort!
              What is the code on your label? Interesting it has a later style relief valve and yet the early body and hub face style. Was L5 the headmarking original for the bracket mounting bolt?
              Bill Caldwell
              • Jim S.
                • March 1, 1986
                • 1398
                Bill ,
                You are welcome. I love when I get to help , rather than just get help from this forum ! Unfortunately , Pictures are practically my only forte !
                As to the rest , on my code , what you see is what you get { 041 }. The rest of the label has delaminated , and the L5 bolt is what was on there when I took it off .
                I don't know if it is correct or not .
                **** Update ! I just checked with the Nolan Adams Fact Book , and it does indeed show an L5 bolt listed . So I will go out on a limb and say it is correct , or at least original . ****
                Jim
                • Bill C.
                  • May 31, 1989
                  • 424
                  Bill ,
                  Jim
                  Jim,
                  Thats great, I have quite a few of the L5 head marking bolts from systems I have scavenged and I always assumed they were later issue. On the date, based on the casting date of the end plate, I will assume the code read something like April 10th thru the 19th? That would make sense based on the build of your car.
                  Bill
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    #24
                    Bill - A couple more data points.
                    66 Chevelle (June 66 build) w/Compressor CODE 050561 has a dehydrator w/o the boss.
                    67 Corvette (Sept 66 build) w/Compressor CODE 072762 has a dehydrator w/the boss.
                    Both appear to be the original dehydrators and both have evidence of the painted over inspection stickers, i.e., some remains & some areas of bare metal where the stickers came off.
                    Pete
                    • Bill C.
                      • May 31, 1989
                      • 424
                      #25
                      Pete
                      Peter,
                      Thanks, on the two compressors, which body style are they?
                      Bill
