If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
How much can a date code on a radiator for a 1965 corvette precede the date the car was built. Build date was June 24, 1965.
Up to six months prior to the car's final assembly date, as with other dated components; however, 2-6 weeks is more typical. If you're buying a new DeWitt's reproduction, they'll date it for you. If you're thinking about buying a used original, DON'T.
