Most Accurate Bias Ply White Line Tire for a 67?
  • David S.
    • August 10, 2009
    • 595
    I'd prefer to go with a BFG something similar to a Silvertown 660 as I have an original spare. What BFG's are acurate and where should I buy them? Coker? Otherwise, what repro bias ply tire do you all recommend?
    Dave
  • Michael J.
    • January 27, 2009
    • 7033
    Re: Most Accurate Bias Ply White Line Tire for a 67?
    I think Coker is the only one with bias ply BFGs with the 5/8 inch whitewall. They ride better than the Firestones or Goodyears, which are nylon and flat spot pretty bad, I think the BFGs Coker makes are polyester, so not as accurate as the nylon ones.
    • David S.
      • August 10, 2009
      • 595
      Thanks. Any other suggestions....?
      • Peter L.
        • June 1, 1983
        • 1930
        I got the Kelsey Goodyear Power Cushion whitewalls for my 67. They judged with the standard deduction. As Mike mentioned they have a flat spot after standing, so from that perspective they are just like the "original" tires; but they drive OK. I drove them 100 mile to the Regional in Albuquerque last year.
        Also, the spare tire doesn't have to match the road tires, it is judges separately. So whatever your original spare is will work fine.
        Pete
        • Michael J.
          • January 27, 2009
          • 7033
          Pete, yes, Kelsey does have them, here:
          Search Our Tire CollectionSearch for Tires by Size, Sidewall Design, or Year of the VehicleGoodyear Collector SeriesKelsey Tire is the exclusive distributor
          • David S.
            • August 10, 2009
            • 595
            I've bought from Kelsey in the past. They made a great product. To me however, there aren't too many BFG tires on the show field and BFG's will match the spare, so I guess the Coker 5/8 will be best?
            Dave
            • John C.
              • January 1, 2005
              • 616
              Dave
              It sounds as if you are trying to get maximum judging points. Coker was not an original supplier of tires in 1967, therefore you will receive a greater deduction for them then you would for an original supplier tire all other things being equal.
              John
              • Peter L.
                • June 1, 1983
                • 1930
                John - You are correct. In fact, as far as I know, none of the suppliers including Kelsey, Coker, etc. of currently available reproduction tires that were available in 1967 are the OEMs. To receive no deduction you would need NOS OEM 1967 tires; the next least deduction as specified in the Judging Reference Manual is for reproduction tires that match the OEMs and trade names as listed in the TIM&JG. Pete
                • Michael J.
                  • January 27, 2009
                  • 7033
                  Right Pete, and people need to remember the Coker and Kelsey tires discussed here do not have Coker or Kelsey on them, they are Goodyear, BFG, Firestone, and the molds used are the same as the OEM ones, but they are DOT stamped of course.
                  • David S.
                    • August 10, 2009
                    • 595
                    So to recap, if I go with the 5/8 white wall BFG tires from Coker, they will receive the same points deduction as the 5/8 white wall Goodyears from Kelsey...?
                    Dave
                    • John C.
                      • January 1, 2005
                      • 616
                      Yeah, I blew it. I don't know why but I was thinking Dave was looking for a radial tire that would earn the max points. If that was true the Coker classic certainly wouldn't be the way to go.
                      John
                      • Michael J.
                        • January 27, 2009
                        • 7033
                        Dave
                        Yes, that's right, 10% (3 pts. deduction), since they are DOT stamped, on originality.
                        • Terry B.
                          • September 1, 1999
                          • 607
                          Dave
                          You need to be interested in the tread count on the tires too. I know for my '68 tires, and I would assume for '67's too, Coker is incorrect and Kelsey is correct. A real easy way to spot a poor replacement tire is the tread count. Don't make a $ mistake if you can avoid it.
                          Terry Buchanan
                          Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                          Corvettes Owned:
                          1977 Coupe
                          1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                          2003 Electron Blue Coupe
                          2019 Torch Red Grand Sport Coupe
                          • Dick W.
                            • July 1, 1985
                            • 10483
                            And some of the repros do/did have incorrect nomenclature on the sidewalls
                            Dick Whittington
                            • Michael J.
                              • January 27, 2009
                              • 7033
                              I don't know about all that, but I bought a set of four BGF Silvertown bias ply redlines for my '67, and there was only a 3 pt. originality deduction at the regional due to the DOT stamp, all else was fine.
