1957 Wanted: ignition coil
  • Susan M.
    • January 10, 2011
    • 63
    Does anyone know wherre I can find an original ignition coil (1115091 aka 091) for my 1957? Thank you!
  • Joe M.
    • May 1, 1990
    • 1337
    Re: 1957 Wanted: ignition coil
    Originals with the "12V" and "091" stamped in the correct location are extremely hard to find now. I have been searching for a month with no luck. There are vendors with "091" coils for sale, but they are reproductions or later models with the 12V and 091 stamped near the top of the coil case, not near the bottom as original.
    • John F.
      • March 24, 2008
      • 2389
      Should look like this!
      • John S.
        • July 30, 2009
        • 640
        if you want a 091 coil identical to the one pictured call pronesti classics, cell number 352-638-5778. the coils are identical and even has the small holes that retain the clips on the top. this is a item that gets sold out as soon as they arrive, so there might be a waiting list.
        • Susan M.
          • January 10, 2011
          • 63
          Thanks Joe. I have been looking for several weeks as well. I'll keep you posted if I find any. I searched for a year for a correct voltage regulator... Susan
          • Susan M.
            • January 10, 2011
            • 63
            Thank you John... Yep, that's the one!!! Susan
            • Susan M.
              • January 10, 2011
              • 63
              Hi John, thanks for the referral. I will give them a call.... correct reproductions??? do they pass judging? Susan
              • John S.
                • July 30, 2009
                • 640
                Susan , send me your email address and i will send you a picture of the coil. i cannot tell the difference between this one and the original.
                • Robert B.
                  • December 1, 1999
                  • 56
                  There is an 091 on eBay for $399.00, item #140661729336. Don't know if its what you want. I have no affiliation with the seller.
                  • Susan M.
                    • January 10, 2011
                    • 63
                    timing is everything. saw that...
                    • Bob M.
                      • March 1, 2004
                      • 66
                      I bought a repo for $99. I took the shoulder/steps off the side of the tower and polished it to make it look like the rest of the top. Next, drill 4 holes in the top for the wire keeper. Looks great except for the 091 being in the wrong place. I haven't had it judged yet, but I would believe just 1 point deduction for the 091 in the wrong place.
                      • Susan M.
                        • January 10, 2011
                        • 63
                        Thanks so much! This seems like a very practical alternative... Susan
                        • Joe M.
                          • May 1, 1990
                          • 1337
                          I only received a 2 point deduct for a 100% incorrect Delco Remy ignition coil. Unless you are willing to spend hundreds of dollars for a correct coil, Bob's plan is the most cost efficient and the appearance will be close.
                          • Susan M.
                            • January 10, 2011
                            • 63
                            Joe, thanks so much. That's great to know... If I don't find one at a reasonable cost I think both John and Bob's approaches are terrific alternatives to consider. I love this tech board!!!!!! thanks again for your input. Susan
