I have read some discussion about using 2x4's to leverage the door into proper alignment with the roof line, or alternately bracing your knee against the inside rear bottom of the window opening while pulling the top of the door toward you, to "bend" the door into a shape that will blend with the roof line. This is also mentioned in Noland Adams' book.
I don't understand what "bending" the fiberglass will accomplish, since it just "bends" right back to the original shape when released. But if the vent window assembly is installed, or maybe the window "sashes", if those are also "bent" during this procedure, they might keep the door "flexed" into the desired position (apparently causing problems with the windows not rolling all the way up, but that's a different issue).
At the moment, I have installed the latches, strikers and the one long weatherstrip that goes around the outer edge of the door, joining the two ends together at the bottom.
I am not having problems with the door-to-roof line (yet), but while reading about test-fitting with the weatherstrip, I found this information also, so I wanted to ask: which parts should be installed before test-fitting the doors?
