65 coupe w P/W Nut 445138 any info? - NCRS Discussion Boards
  • William H.
    • March 1, 1999
    • 249
    Hello does anyone have any info or pictures of 445138 this is a nut that one of the screws that holds on the PW conduit to the door attaches to. It is listed in the 64 AIM MY 65 AIM doesnt have that page. I think that it is just a flat spring type speed nut as there is no room fopr a j nut. Any help would be appreciated as the body shop took these off and I dont know where the hardware is now. Thanks in advance,
    Bill
  • Glen C.
    • November 1, 1985
    • 193
    Re: 65 coupe w P/W Nut 445138 any info?
    Bill
    Bill, I just had my 66 PW conduit out today, the inboard screw goes into a small flat green metal speed nut not a J nut. The outboard screw just screws into the fiberglass or into a similar nut. I can't see the outboard end of the screw inside the door. But my 66 AIM shows item #6 445138 nut in the outboard position in the drawing but none on the inboard screw. I hope this makes sense! Glen
    • William H.
      • March 1, 1999
      • 249
      Thanks alot Glen,
      I found some flat speednuts that are green like you described. They worked fine. The outer screw goes into the metal frame of the door. So, it doesn't need a nut
      Thanks again
      for the info
      Bill
