I have reviewed the archives but still have concerns.
When I try to move the rear wheels in the 12/6 positions I get no movement.
When I try to move the rear wheels in the 3/9 positions I get some very discernible movement, albeit with quite a bit of pressure applied.. (Wheel bearings from what I have read)
I know the strut rods have been replaced by previous owner because they are the newer style. One of the half shafts is missing a lock. I am pretty sure the half shafts have been off the car maybe even when the struts were done. U joints are still originals.
There are 118k miles on vette. I am pretty confident that the trailing arm assemblies are way overdue for rebuilding. (Sending to Bairs) I am pretty sure all the u joints are overdue.
The differential is not leaking or making noise so I am hoping that I can save on having to rebuild the differential.
Any thoughts or suggestions are appreciated.
This all came about because I need tires (12 years old) and an alignment. It would seem to be a total waist of money for an alignment at $250.00 if a year from now I have a wheel bearing or other problem that would require disassembling the rear suspension.
How much should I save if I perform all the labor to remove and reinstall assemblies?
Thanks, Bill
Thanks, Bill
