1972 emergency brake & fasten seat belt lights - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Are the Fasten seat belt light and the emergency brake light inter-related?
    On my car neither of them come on at the same time. For example:
    1) The emergency brake is set and the seat belts have not been buckled.
    2) The ignition is rotated to on and/or the engine is started
    3) The only dash light that comes on is the fasten seat belt. After fastening the seat belt the dash emergency brake light comes on and the seat belt light goes off.
    4) Release the emergency brake and the dash brake light goes off.
    Is this a correct sequence of events? If not, does any one have a corrective suggestion?
  • Jerome P.
    • October 22, 2006
    • 607
    Re: 1972 emergency brake & fasten seat belt lights
    No ideas out there
      • November 30, 1989
      • 11561
      Mine work independently of each other. However, if the e-brake light switch is a bit out of adjustment you're probably shifting it a bit when you reach over and attach your lap belt. It's a plunger switch at the bottom of the e-brake lever's travel.
      Try wiggling the e-brake lever and see what happens, ie. if the light goes on or off.
      Else you may have a grounding issue behind the dash.
