FI air hose - NCRS Discussion Boards
FI air hose
  • Gary P.
    • May 31, 2005
    • 104
    FI air hose
    Can anybody tell me what the number are that on an original 63 F.I. air cleaner hose. Thanks.
  • John D.
    • December 1, 1979
    • 5507
    Re: FI air hose
    Gary, 3825656 AU. John
    P.S. The numbers aren't seen when the hose is installed as the clamp covers it.
    • Gary P.
      • May 31, 2005
      • 104
      Re: FI air hose
      Thanks John.
      • John D.
        • December 1, 1979
        • 5507
        Re: FI air hose
        Gary, You are most welcome. Now for a tip for the gang here regarding that 63/64 hose.
        Although we judges love to see a nice original at the shows you would be doing yourself a favor if you only used that hard as a rock hose for judging. When driving put a repro on. The repros are quite presentable and the rubber is soft. The hose acts like a shock absorber you know and the hard original is only going to cause damage.
        Another thought on the original hoses. My 63, the LWC has an original. I mean it has a big kink and you couldn't get it to flex with a hammer. But should it be on a restored vehicle? Well if it was then one might get full credit for being original but you should get a ding on condition as they didn't come out of St. Louis with a well aged hose on it.
        The hard original should be on a bow-tie car.
        But WDIK. JD
        • Mike M.
          • May 31, 1974
          • 8389
          Re: FI air hose
          john: do you think the early hoses(the hard ones) left st louis bent into a non-straightenable condition. i have several on my midyear FI's some i've owned since 1970, whene they were as hard as a teenager's pride and joy and couldn't be straightened..mike
          • Michael G.
            • November 12, 2008
            • 2157
            Re: FI air hose
            Mike,
            I have an original 63 hose that is probably less flexible than the air cleaner it would be attached to. It also is permanently badly kinked. I believe that, even if I could get it on, something would break the first time I revved the engine....
            Mike
            1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
            1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
