1958 coil spring compression tool
  • Brandon T.
    • October 24, 2008
    • 872
    What type of coil spring comression tool works best ? Should I buy the tool that goes inside the spring or one that fits on the outside of the spring?
  • Dan P.
    • December 1, 1990
    • 683
    Re: 1958 coil spring compression tool
    The one that goes on the inside is the best . On a C1 most of the time you can get by with out it.
    • Bruce B.
      • June 1, 1996
      • 2930
      Check out the procedure in the3 ST12.
      No coil spring tool of any kind is needed to remove or install the springs.
      • Dennis C.
        • July 1, 2002
        • 881
        Brandon,
        Search the archives for some good information. A piece of 1/2" threaded rod can be used to compress the spring. It gets installed thru the center of the spring with some blocks on the end.
        Dennis
        • John L.
          • February 1, 2005
          • 207
          Indeed I am in the process of rebuild of the front end of my 1954 and using the 1/2" threaded rod and have not had a problem - but as mentioned it may help with a little piece of mind to have a "safety chain" installed on the coil.
          Good luck!
          John
          • Tom P.
            • April 1, 1980
            • 1811
            Scroll through here until you find it. I put this together over a year ago.
            It will take more time to explain it than it will for you to look at the pictures.
            Chevy Forums FREE technical assistance for your restoration and repair. Model specific subject matter experts, classified ads and more.
            • Dennis C.
              • July 1, 2002
              • 881
              Good luck!
              John
              Absolutely! I used a short wire rope sling and made sure it was secured.
              Dennis
