Please confirm spark plug gap 327 300 horse. thank you a/c 45
a/c 45 plug gap
- Top
Re: a/c 45 plug gap
If you're running stock points ignition, by all means stick with the standard gap spec.
If you're running electronic conversion with a higher output coil, you probably can find some advantage with a wider gap - though there are many sceptics that may not agree.
Stu Fox- Top
