'58 trim plate for 4 speed & ashtray - NCRS Discussion Boards
  • Don E.
    • April 30, 2005
    • 65
    I am looking for some guidance on the correct mounting nuts for the 4 speed shift trim piece that covers the shift hole and holds the ashtray.
    Does anyone have and pics and/or description on the nuts that are on the underside of the transmission tunnel, that the two bolts mount to? Are these nuts affixed to a plate that is supposed to be riveted to the tunnel or are the nuts simply fiber glassed to the underside of the tunnel?
    Currently I have what appears to 1/2' holes w/bevel cut; however there is no nut or mounting plate to screw the bolts into.
    Any information would be greatly appreciated.
    Don
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11320
    Re: '58 trim plate for 4 speed & ashtray
    Don, These are what's available in reproduction. I believe they clip into a square hole in the FG. You can see the tangs in the pic.
    e.g. Zip PT# ST-433
    Rich
    • Paul M.
      • November 1, 1987
      • 142
      Rich, you are correct but they go into the round holes that Don has.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11320
        Paul is right. They're round. I just went out to the garage and these are on the '59 I have apart. The holes are apx 3/8" round.
        ........Rich
        • Don E.
          • April 30, 2005
          • 65
          Richard/Paul, Thank you for the information and pictures. It is clears what I need.
          Thanx again,
          Don
