If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
The FI auto used the 3752490 rod and bracket assy and the 3750537 upper rod I can't find the lower rod number. Am looking for a source for all the items any ideas?
thanks RDR
My 58 AIMS has a very poor copy of the info Ronnie. I don't think it will be a whole lot of help to you. but it's a start. Page 157 in the Millenum Industries copy.
For a perfect pic of that bracket see page 266 in Vol 1 of Noland Adam's.
Then turn to page 289 for a mint photo that Noland took out of the aims.
By the way Ronnie and others. If you are missing the FI accelerator return spring extention there is a print of that part in Nolands as the repro is too long. You are better off with making one yourself and making it a tad shorter than longer. Go to Lowe's and buy some S shaped hooks in a baggie then bent up your own and blacken it.Piece of cake. No I don't sell them.
See Page 290 in Nolands for the print on that spring extension.
John/John
I have the firs addition 4th printing. From what I can see here 'It appears that the page 266 brackett is 3751674, for a carb. car?? The cut away on page 289calls fot 3752490??? I can't find the picture except on page 288?? It is not very helpful. It appears to me that the carb bracket which I found is too long for the FI car?? Any comments thanks RDR
