59-62 clutch push rod - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8408
    anybody got the overall length of this critter. i suspect i put a 55-58 rod in my 62 with resultant pedal sticking to the floor(spring going over center).the 55-58 is an 18" AOL according to the P&A.they give no dimensions for the 59-62. thanks,mike
  • Donald L.
    • September 30, 1998
    • 461
    Re: 59-62 clutch push rod
    Mike,
    The rod on my 62 is about 9.5 inches.
    • Bill M.
      • April 1, 1977
      • 1386
      Mike:
      I get 18-1/8 for my '59. It is original. It has a slight bend in it.
      Bill
      (It will go over-center by design if it's not hooked up to the clutch.)
      • Joe R.
        • July 31, 1976
        • 4552
        Mike,
        Have several and you are welcome to one if needed. They are 9 3/8" from hole center to the end of the threaded rod. My rods came from GM.
        JR
        • Mike M.
          • May 31, 1974
          • 8408
          guys: my question refered to the rod that runs from the clutch pedal arm down thru the firewall to the bellcrank. mike
          • Bill M.
            • April 1, 1977
            • 1386
            Mike, read #3
            • Gene M.
              • April 1, 1985
              • 4233
              Mike, did you use a finger or diaphram clutch? The diaphram type if there is too much throw can over center and sit on the floor.
              • Donald L.
                • 461
                Mike,
                I measure about 18". 6" from the Z bar to the firewall and 11" from the pedal to the inside firewall. Firewall about an inch thick. This is on a 62 w. the original rod using a three finger Ft Wayne clutch.
                  • 43285
                  Mike-----
                  Irrespective of length, I believe it's easy to tell the two apart. The 55-58 rod is completely straight and has a 90 degree bend on one end. I believe the 59-62 rod has about a 5 degree bend near the center of the rod and has eyelets on either end.
                  • Mike M.
                    • May 31, 1974
                    • 8408
                    Mike-----
                    joe: you're absolutly correct as i've been working on the clutch problem all morning. i took the 56 clutch rod and compared it to the 62. the 62 has a female on each end of the rod and the 55-58 have a female on one end and a male on the other so they can't be interchanged without fabrication. my problem was the clutch pedal wouldn't return to the engaged position after i shifted gears. i discovered the rubber stop on the clutch/brake pedal assembly was way too thick. i sliced it down about 75% and got it working. thanks guys,mike
