1965 L78 Vac - NCRS Discussion Boards
1965 L78 Vac
  • Brenton M.
    • May 31, 2006
    • 66
    1965 L78 Vac
    I purchased a new Vacuum advance can for my 65 L78 engine from Napa the part number is VC1765, It looks a lot different from the one that's on my car now.
    Can anyone tell me if there's any modification needed to be made to install this VAC.
    • 15678
    Re: 1965 L78 Vac
    The VC1765 should be stamped B20 or B26 and other than some minor details is dimensionally identical to OE VACs for the single point/TI distributor.
    So what's installed now. ID number? Is it a correct TI distributor? A photo would be good, too.
    • Brenton M.
      • May 31, 2006
      • 66
      Re: 1965 L78 Vac
      Thanks Duke, I purchased the VAC from a napa parts store using the part number VC1765 the one that they gave me did not look any thing like the one that came on my distributor, So I made a trip to O'reillys Auto Parts I gave them the napa parts number that i had which was VC1765 they cross reference that number to there number V375 was there number, the can looked exactly like the one i took off my distributor it was stamped with the letters B26 i think this is the one i need.
        • 15678
        Re: 1965 L78 Vac
        It sounds like NAPA mispackaged the part, so take it back and let them know.
        The B20/B26 is functionally correct for SHP big blocks, and I think L-78 has full time vacuum advance, but check to be sure.
        I believe the original L-78 VAC is ...201, but it doesn't meet the Two-Inch-Rule, same as my '63 L-76, which also had the ...201 as OE - didn't meet the Two-Inch-Rule, which caused a lot of idle instability problems.
