1979 Front Coil Spring Decals - NCRS Discussion Boards
  • Schanen C.
    • February 1, 2010
    • 122
    Hi All,
    What are the Correct Front Coil Spring Decals for my 79 with Standard Suspension ??
    I have found on e-bay a set with Papers from a 1978 and these Decals have the Numbers AJ 346940 .
    Also i want the Metal Liners for my Rear Spring,others have the Plastic ones,who can Help me to find these Parts Please.
    All Comments Welcome.
    Thanks in advance.
    Carlo
  • Tom R.
    • June 30, 1993
    • 4100
    Re: 1979 Front Coil Spring Decals
    Originally posted by Schanen Carlo (51311)
    Hi All,
    I have found on e-bay a set with Papers from a 1978 and these Decals have the Numbers AJ 346940.
    Front coil springs were computer selected and in 1978-79, there were 20 different selections dependent on vehicle weight, tire size and engine. Unless you have your build sheet, you will be unable to identify the coil spring installed on your vehicle. Only ten selections for a base suspension. You could recalculate all that if you're ambitious but than, it depends on what you're attempting to accomplish.
    Having said that, the AJ spring was used in 1979 and, more than likely, will work for your application. Top Flight judging does not judge the front coil spring broadcast code and Bowtie would only judge the presence of a broadcast code tag.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
