I am rebuilding a standard 66 steering column and cannot determine the part that goes into the slot on the steering column jacket bell - top of steering column - passenger side. I have found a "turn signal housing lock wedge with screw" that seems to be what I need, but it's listed for 53 -63 only.  Can anyone tell me what I need and where to get it?
					66 steering column rebuild
Re: 66 steering column rebuild
Do you possess a ASM for a '66 Corvette? Invaluable for these cars.I am rebuilding a standard 66 steering column and cannot determine the part that goes into the slot on the steering column jacket bell - top of steering column - passenger side. I have found a "turn signal housing lock wedge with screw" that seems to be what I need, but it's listed for 53 -63 only. Can anyone tell me what I need and where to get it?- Top
Carl,I am rebuilding a standard 66 steering column and cannot determine the part that goes into the slot on the steering column jacket bell - top of steering column - passenger side. I have found a "turn signal housing lock wedge with screw" that seems to be what I need, but it's listed for 53 -63 only. Can anyone tell me what I need and where to get it?
If I remember correctly, the hole, screw and wedge were only used for past models but not 64-66. The hole should be open/empty.- Top
