427 TI Problems
Re: 427 TI Problems
Thanks, Mark. Appreciate the expertise and will do.Bill Hyndman
The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
1962 Big Brake Fuelie
1965 Fuelie Convertible
1968 L89 Convertible
Re: 427 TI Problems
William,
I agree with Dick, you can use aerosol to find the leak or unlit propane gas bottle. Problem with aerosol is that everything you spray will remove paint so be careful. Try to plug the power brake vacuum take off and the vacuum to the vacuum tank to isolate the engine as the problem.
If the car is warm at curb (low) idle, and the choke needs to be closed to idle the engine there is a good chance it's a leak with one of the holleys. Best way IMO to tune troubleshoot tri power is to remove and block off end carburetors and tune primary carburetor first then install end carbs and tune for WOT A/F ratio. If the camshaft and compression is stock the factory jets, power valve etc will get you a good running car. I think the end carbs have a metering plate instead of metering block so lots of places for vacuum and gas leaks.
What was done to the carburetors when you stste they are set to factory settings..- Top
Re: 427 TI Problems
Thanks, Dick. I'm going to give that a try tomorrow. Appreciate your expertise. BillBill Hyndman
Re: 427 TI Problems
William,
What was done to the carburetors when you stste they are set to factory settings..Dick Whittington- Top
