Parts # Identification - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1283
    Can someone help me identify these parts?
    Oil Pump Metal Tag DM 55 98317A Embossed casting # 419 and raised casting # 307
    Thermostat Housing # 3827369
    Water Pump # 3839175 Dated L 8 8
    • 43222
    Re: Parts # Identification
    Jerry------
    The oil pump is an aftermarket Melling M-55 which services most 1958+ small blocks.
    The GM #3827369 thermostat housing is applicable to many 1955-68 Corvette applications. However, it was released in the late 1962-1963 period so it was not ORIGINALLY used for any applications prior to that time. There are quite a few very slightly different "variations" of this housing all of which are functionally interchangeable.
    The GM #3839175 waterpump casting was used for 1964-E1965 small block applications requiring external by-pass (i.e. SHP and FI). It may also have been used for very late 1963.
    • Gerald C.
      • June 30, 1987
      • 1283
      Thanks Joe!
