Hi all, I've installed a U58 radio in my '72. I know it is not correct for the year and was hoping someone that has their dash apart could take a picture of its correct mounting in the car. If it matters, I'm not sure, I have an A/C car. Thanks!!
Picture of mounted U58 convector mounting
Re: Picture of mounted U58 convector mounting
Not sure if this will help or not?
I have a 70 non A/C coupe and just re-installed the 74 AM/FM Stereo (U??) that came with the car.
It only had three attachment points, the 2 nuts that are under the control knobs that secure the radio to the center console, and behind the center console (out of sight) is 1 metal sheetmetal strap that attaches to the right side of radio (as you look at it) and connects to an angle bracket on the transmission tunnel/floor of the car.
The amplifier (if there is one) mounts to the underside of the dash behind the glove box/pocket.
MikeLast edited by Mike F.; June 24, 2011, 11:11 AM.- Top
Lynn, I've got a photo, and as soon as I find it I'll PM it to you. May be a few days, as I go back to work for 6 days on Saturday.Kurt Geis
Chairman, Midway USA Chapter
Targa Blue 1972, Top Flight and Duntov Award, 2014
Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
Arctic White 2013 60th Anniv Special Edition Conv.- Top
Thanks for the replies.
Mike, Thanks but I'm looking specifically for the amp/convector mounting. I've successfully installed the radio itself.
Kurt, looking forward to the pic you have, no huge rush though.
Tom, those are the components from my U79 that i removed. Unfortunately the amp/convector does not use the same mounting holes as either of the two components shown in your pics.- Top
Mine looks just like Tom's. It's a very early '72 car, but looks the same.Kurt Geis
