'69 L-71 piston design question - NCRS Discussion Boards
  • G A.
    • February 18, 2010
    • 229
    I want to make sure I have the original design wrist-pin and I can't recall for sure what they were. Were the factory pistons a center pin or off-set pin, and were they pressed fit or floating pins? Hopefully someone here has a better memory than me.
    - Dan
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: '69 L-71 piston design question
    for sure pressed pins and if it is a cast piston most likely a offset pin.
    • Michael H.
      • January 29, 2008
      • 7477
      - Dan
      If I remember correctly, the 390/400 HP pistons had offset pins but the L71/435 HP pins were on center.
      • G A.
        • February 18, 2010
        • 229
        Thanks gentlemen. My recollection was a center pin but I couldn't say if they were floating or not. The dimple rods certainly had pressed pins though. Would anyone know what current manufacturer has good duplicates (pressed, center pin, 11:1 comp)??
          • 43222
          Dan------
          The original pistons were forged aluminum, center pin, and press fit. Until the LS-7 came along a few years ago, the only Chevrolet engines that ever used floating piston pin design were 1969 Z-28, 1969 L-88 and ZL-1.
          If you want to stay with a forged piston, Speed-Pro/TRW is probably the best way to go for a street engine.
          • Richard F.
            • May 31, 1986
            • 193
            68 L88 used floating pins with 3/8 rod bolts as Joe has pointed out before.
              • 15680
              The '69 AMA specs that you can download from the GM Heritage Web site should have that information.
              The '63 AMA specs state that the 250/300 HP engine pistons had .060" offset and the 340/360 HP engine pistons had none.
              • G A.
                • February 18, 2010
                • 229
                Thank you all for the feed back. Now on to the search for the pistons.
                Dan
