I recently detailed some of the cars front components with a few yet to go... 60 FI Big Brake, so she has the quicker steering plate.
There is a large ROUND thing in the center of the car can't remember what its calledfor the steering. There is a FELT or RUBBER GASKET WASHER ON the OUTSIDE of it... how important is that to be in good shape, it is all strecthed out...
I would say its about a 2-3 inch round by 1/4 high washer/gasket.
Also I can see its available at the repo places, is this something hard to install, it appears I can remove the adapter plate and slide a new one all the way up and over? Or must I seperate something, I had checked the part for crackes as I read people make the mistake and sometimes jack the car there, but it all looks fine... side question is it OK to jack in the center of the front crossmember or not? Is one uses a peice of wood to spread the jack load off the small puck?
thanks
thanks
