I'm changing my door ajar switches to the SX style and have a little problem with the adjustment of one of the switches in the door jamb. If I screw the nut on the switch all the way in, the door ajar light will not go out when the door is shut. If I loosen the switch to about half way out it works fine but it is not secure. Is there a spacer or special washer that the factory used to make this fine tune adjustment?
