68 corvette sb hood - NCRS Discussion Boards
68 corvette sb hood
  • Jim R.
    • June 30, 2001
    • 643
    68 corvette sb hood
    I will soon be shopping for a original 68 small block hood and was wondering if all 68-72 sb hoods are the same or if there is something different i need to be looking at for a correct 68 hood, didn't some have insulation tabs and some not.
    • 15634
    Re: 68 corvette sb hood
    There are more differences than insulation. The passenger side hood latch changed in late 1969 (bolt pattern is different) and the location of the hood prop changed in 1972.
    Both of these features are illustrated in photographs in previous threads. They might even be among the four or five automatically linked at the bottom of the page4, if you scroll down.
    • Jim R.
      • June 30, 2001
      • 643
      Thank's Terry, I will check it out
      • Grant W.
        • December 1, 1987
        • 407
        Hi Jim
        68's has 2 hood cable clamps. One in the middle and one off to the Right.
        Hope this helps you get the right one and not spend extra $$$ on the wrong hood.
        Thanks, Grant
          • 43281
          Jim------
          The easiest way to identify the hoods is as Grant suggests----look for the anchor points for the TWO cross cable clamps. Later hoods have only one.
          The hood you need was used from the start of PRODUCTION 1968 through about sometime in October, 1969. Any of these hoods will work for you.
          You can also use a later hood, but if you do you have to use the late1969-76 upper hood latch plates and the corresponding cross cable (black sheath). While the lower hood latches can remain the same, the latch bolts have to be changed to the "cone" style (in order to work with the late1969-76 upper latch plates).
          • Jim R.
            • June 30, 2001
            • 643
            Grant and Joe thanks for the 68 hood tips ,it will really help me in finding the correct hood for the 68. Jim
            • Richard F.
              • May 31, 1986
              • 193
              Jim, I sent you a personal message.
