Have installed a Corvette Central repop shifter and repop rods on a fully restored 1960 Vette transmission. Transmission is an original 1960 4 speed date coded transmission.
Test ran the car today and the shifter would not engage third gear. I used the metal block to set up in neutral, and adjust gears, so I know that was correct. I jacked the car up and discovered the rod was not going all the way back for third gear, so I lengthened the rod as required. But, the shift position compared to first gear is weird. In first gear, the shift knob is all the way forward, in third gear it is about 2/3 forward as compared to the first gear position of the ball handle. Is this normal for an original transmission 4 speed 60 Vette? I'm taking the car for another test run to see if she will shift into third now.
Thanks for any assist.
Jim
Jim
