I'm finally getting around to sorting out this body lean issue on my 60 and would like some words of wisdom. I think it's 90% springs and 10% actual body and this is what I've done so far. Also for what it's worth,this was all done on a cement floor so it's not 100% accurate but I think it's fairly close because of the way I did it.
The front measurement between the lower control arm front grease nipple and floor(Front Dim. A) is, drivers side-10-1/8" & pass side-10-5/8"
The rear measurement between the bottom of the frame kick-up and top of the axle tube(Rear Dim. B) is, drivers side-6" & pass side-6-1/2".
The rear leafs were new replacement ones(non-groved) when I bought the car and the front coils look like originals so I'm thinking that new front one will take care of it. I also read some place that there were shims used along with the coils and I was wondering how thick they were, how many were often used and if they went on the top of bottom of the spring? I wonder if maybe I have a shim issue or if not maybe I could use some to level the car if the new coils don't do it.
Now if I jack under the divers control arm cross shaft to level the frame(both Dim. A is equal) and then lay a 4' level across the fender tops just ahead of the hood I still need to raise the drivers side of the level about 3/16" to make the level, level so that tells me that the body also has a bit of lean or is this not a good way to check this?
If it is actual body lean then where do I go to raise this part of the body and seeing as it's just a driver I'm wondering if I even want to go there....
. Some very early repairs by a Chevy body shop that was made back in 1960's when GM parts were used to fix them as factory correct just as you would have done as todays new car, I think & hope(modern throw a way cars)? Make a "X" measurement if possiable on top surface of fenders headlight bezzel from outer corner to an opposite area like the edge of fender/door gap space. I don't think there is such a thing as perfect, but should give you a feel as how square that area may be. Just a though.........
