62 oil pump - NCRS Discussion Boards
62 oil pump
  • Jerry P.
    • September 30, 1989
    • 85
    62 oil pump
    62 327/340 oil pump.... how do you tell if the pump is a HV or HP... the # on my pump is 28012 embossed on the body is 42-43 K9... tag under one of the screws is 41-43 I want a stock pump #'s please thanks for the help jerry
    • 43222
    Re: 62 oil pump
    Jerry-------
    I doubt that the pump is an original or, even, GM SERVICE piece.
    You can tell if it's a high volume pump by measuring the length of the gears. A standard volume pump has gears which are 1.3" long and a high volume pump has gears that are 1.5" long.
    As far as pressure goes, the only difference between a standard pressure and high pressure pump is the installed spring. However, it's difficult to visually discern the difference between the springs especially if the pump is aftermarket which yours likely is. A high volume pump is always high pressure, so if you do have a high volume pump, then you know it's also high pressure.
    The original oil pump for your application was GM #3764547 and it was a standard pressure, standard volume pump. I believe it was manufactured internally by GM. It's long-since GM-discontinued, though, and superceded several times. The current GM pump is GM #12555284. However, I don't think this pump is manufactured by GM and is likely of Melling manufacture. It might be the same as a Melling M-10553. Both pumps cost about the same, so you might want to go with the GM piece.
    • Jerry P.
      • 85
      Re: 62 oil pump
      Thanks Joe saved me a lot of time wouild of been a PV flunk jerry
