67 tele column questions - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    hello I have a late 67 column part number 7803280 with a date of 178 7. when bench testing the column out of the car you can move the hub about a inch away from the mast of the column with out locking the ring. what is going on. you can see the turn single switch so I know the horn or canceling cam will not work. also should the lock ring have one or two knobs. this one only has one. thanks
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 67 tele column questions
    Keith,
    If I remeber correctly. Thats a bad upper bearing. the 67 upper bearing is part of an assembly, when it seperates/brakes it allows the colum to do excactly as you describe. Need to find an upper bearing assembly.
    Rich
    • Keith B.
      • March 7, 2008
      • 928
      okay thanks LIC sells one part# 18-21C. I am guessing that is the one. is it a simple repair?
      • Keith B.
        • March 7, 2008
        • 928
        Anybody know about the lock ring and the number of knobs
        • Jim S.
          • August 31, 2001
          • 730
          This is from my 1968 Chevrolet Chassis Service Manual.
          You can see a second knob on the locking ring. Whether this is the same for 1967 - you would think so.
          Doc Rebuild lists the following:
          67 Tele Lock Ring Chrome 2821207
          68 Tele Lock Ring Black 2821210
          So two different rings 1967-68. But no indication as to both of them having two knobs.
          jim
