85 MPH, Texas speed limit - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Re: 85 MPH, Texas speed limit
    Summer, 1967 -just turned 21 - LA to Vegas - increased revs to 5000 on the 3.08:1 axle 327/340 HP SWC when I crossed over to Nevada, which had no speed limit at the time - 130 MPH indicated, no traffic.
    ...made the approximate 40+ miles to the Strip in 18 minutes.
    It doesn't get much better than that. It's what high powered sports cars are all about!
    The only better time I had on the road was the two Silver State Classic Challenges I ran in 1989 and 1990. First year the '88 Merc 190E 2.6 five-speed maxed out at about 132 @ 5100.
    The next year the Saleen Mustang I prepared and drove made high 150s at 4500.
    Fall of 1970, on a brand new unopened road just completed, 3 mile stretch straight as an arrow, almost level, I figured I'd test my 67/327/300/3.08.
    The speedo was showing 135, the tach at 5300, not sure the exact speed with the two year old Michelin X radials. Stopped my test when a slight crosswind shifted my front end across the road. The front end was floating and I was about to take off. Worried about the two year old tires, and the convertible top (my original), I ended the test on the third run.
    I'll never forget the sound and the roar, and the compression on the convertible top. At age 25, it was quite a rush, and never to be repeated again with my 67.
    I guess we were a little crazy when we were young.
    Jerry Fuccillo
      • 15679
      I think most of us have come to grips with our mortality since we did crazy things with cars, motorcycles, boats, airplanes... whatever back when we were young and immortal.
      • Stuart F.
        • August 31, 1996
        • 4676
        #18
        Jerry;
        The phenomenon you describe with your 67 at 135 is typical with the C-2's, as I'm sure you know by now, i. e. "Larry's Wing Effect". We didn't know back in 63 when my buddy and I went to Vegas. We tried to see how fast ours would go (340hp w/3.36). When my buddy was driving, I could swear I saw 150 from the passenger seat, but the needle was bouncing cause we were nearly flying! (lots of wheel slip too with OEM U.S. Royal tires - crazy, huh?). It was, no matter what speed we were actually going, very unstable. On one of my stints, I was cruising along about 130 or so and hanging on for dear life. We came upon an area that looked like an imminent rain shower so I opened the headlights and experienced an immediate improvement in front end stability. It just pulled the front end right down. We, unknowingly, learned something about aerodynamics that day, and I have continued to open the headlights for higher highway speeds to this day.
        I often wondered if anyone else had a similar "open headlight" experience with a C-2.
        Stu Fox
        • Ronald L.
          • October 18, 2009
          • 3248
          #19
          Stu, at 100mph the 427 keeps the front end down that puts me a 4000rpm and the side pipe noise is so loud you won't stay at that velocity long.
          • John D.
            • June 30, 1991
            • 875
            #20
            67/327/350HP/M20/3:36 = well matched combo in my opinion
            • Stuart F.
              • August 31, 1996
              • 4676
              #21
              This may be just my imagination, but it seems that most of the big block C-2's seem to adopt a "nose up, tail down" attitude even at speed with that extra weight up front where as a small block tends to exhibit a full body lift. Either way, I'm sure they are both a hand full.
              Stu Fox
