If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Rebuilding a T-10 for a 63...is the spline or output shaft a 16 tooth or a finer 24 to 26 tooth?
Henry-----
It's the course spline. I don't recall if it's 16 teeth but it's definitely not the 26 spline. The 26 spline was used from 1965 to 1967 as well as 68-70 with manual transmission. 32 spline was used for 68-70 with THM as well as most 71+.
If it's really a '63 transmission the front input shaft cover will be smaller in outside diameter where it centers in the bellhousing. This is a one year only transmission and makes the bellhousing one year only also.
Muncie 4-speeds never used a course spline(16) out put main shaft, 27 spline 1963 1/2 thru 1970, 32 spline 1971-74 and 1970 BB Chevelles...
Hope this helps... Eric
My P & A catalogs (65 -67-69 ) say otherwise; #3868728 would be the fine spline yoke.
Ray
Ray-----
Yes, 1963-64 with Muncie did use a 26 spline output (main) shaft. However, the transmission yoke was not originally GM #3868728. The original yoke was GM #3832678. The 65+ yoke, GM #3868728, replaced it for SERVICE in January, 1965.
