If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
hey guys...my passenger front insulator on my side pipe cover came loose and is almost falling off. what is the best adhesive to fasten it back on with?
thanks in advance.
thanks in advance.
Kevin -
Friend of mine used JB Weld on his about eight years ago, worked fine.
