Point loss for direct fit aluminiun radiator - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    Does anyone have experience getting a car judged with a Dewitts direct fit aluminium radiator when the car is supposed to have a copper brass unit? I would really like to use the aluminium radiator instead of recoring my old one. Thanks
    Mike
  • John C.
    • January 1, 2005
    • 616
    Re: Point loss for direct fit aluminum radiator
    Mike
    I have a 1967 was restored by the previous owner more to be driven than to be an NCRS car and he put in a Dewitt's direct fit radiator. I have the scoring sheets from when he had it judged. He lost 7 points for the aluminum radiator.
    John
    • Mike R.
      • August 30, 2009
      • 321
      Thanks, that is better than I would have thought
      Originally posted by John Carlson (43123)
      Mike
      John
      • Dick W.
        • 10483
        Re: Point loss for direct fit aluminiun radiator
        Mike, I notice in your profile that you own a '65. If this is the car you are talking about, your car came with an aluminum radiator from the factory, small block or big block.
        Dick Whittington
        • Michael J.
          • January 27, 2009
          • 7167
          Yes, it is not bad, and definitely worth every point deducted as the DeWitts beats the originals by a mile. I love mine and it solved all the problems I used to have.
          • Ronald L.
            • October 18, 2009
            • 3248
            I did not look at DeWitts 65 BB rad when up there, only the 66 that I needed, you could not tell the difference to the original, and performance is fine. This entire aluminum vc copper is subject to too many other variables (written about on this forum often) that rad for rad its unlikely you'll note the difference. Its almost like putting on Ford hubcaps just get a real one...
