54 rear spring front eye bolt - NCRS Discussion Boards
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 162
    My 54 rear leaf spring front eyebolt doesnt have a locking nut.
    My 61 has side punched locking nuts ( nut side wall is punched on 2 of 6 sides to wave threads and lock nut.)
    Is nonlocking correct, and what year was the change?
  • Chuck G.
    • May 31, 1982
    • 2034
    Re: 54 rear spring front eye bolt
    Should have a plain old nut on a 54.
    Chuck
    • Mike M.
      • May 31, 1974
      • 8389
      agree with chuck. all the c-1's i've restored had a standard hex nut but the end of the bolts were peened to prevent the nut from loosening. mike
      • Troy P.
        • February 1, 1989
        • 1284
        As I recall, the 56-57 Corvette AIM shows the use of lock washers in this application. It also gives the torque spec. So I was surprised to hear from some very experienced restorers that they've not found lock washers.
        • Jim L.
          • September 30, 1979
          • 1808
          My unrestored, unmolested #3300 '54 has a split washer under the nut, no evidence of staking.
          Jim
          • Troy P.
            • February 1, 1989
            • 1284
            I checked the AIM and it does call for a lock washer in 56-57. So I'm thinking, based on my observations and Jim's, that from at least 53-57 washers may have been used. But perhaps they were deleted in later C1s?
            For what its worth, there are no washers on the spring shackles at the other end of the spring.
            • Chris S.
              • January 1, 2000
              • 1068
              my unrestored chassis - 3803 had a nut and lock washer
              I saved them and photo'd it.
              1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
              Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
              1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
              1957 Corvette - FI 3 sp - Black and Silver
              • Troy P.
                • February 1, 1989
                • 1284
                And your other 54?
                • Chris S.
                  • January 1, 2000
                  • 1068
                  Troy - I will check !
