1965 corvette big block headlight wiring harness that runs down left fender well, does it go over te top of core support , I know it runs underneath the header bar, but i dont know how its routed threw the core support.
Headlight wiring harness
Tags: None
- Top
Re: Headlight wiring harness
I thought it might be good to post a picture of my '64 with the hood off. I have just been rebuilding my headlight motors and buckets. I just installed a headlight harness. There is a nice little area at the end of the radiator support for the harness to pass. This is not a hard task. I happen to get my harness from Eagle Wire Products now located in Ohio and I am very pleased.Attached Files- Top
Hi guys, Rich, Wayne showing off His solid state voltage regulator.I thought it might be good to post a picture of my '64 with the hood off. I have just been rebuilding my headlight motors and buckets. I just installed a headlight harness. There is a nice little area at the end of the radiator support for the harness to pass. This is not a hard task. I happen to get my harness from Eagle Wire Products now located in Ohio and I am very pleased.
Dale you need a clip to hold your harness to the radiator support, it clips on the side of the support about five inchs down. Phil 8063
- Top
Rich, Phil -- yup
; but sharp eyes would have seen that it's a 1111678_B, and not the correct 1116368 for '65 L79 or L76 w/C60 and K66. I've also got 3 NOS of the 368's (dated 4H -- correct for my Nov. '64 car, and a 4K and a 6A).
The three TI amp mount (empty) holes can be seen on the rad support; been at least 30 years since there was something functional there.
Problem is, I accumulate this stuff but drag my rear when it comes time to install
. I'm a junior member of the NCPS -- National Corvette Packrat Society; and we all know who the president is
- Top
Phil, thanks for catching my missing clip. It must have been omitted when someone a few years ago replaced the radiator support. I just want to clarify, this clip is on the front side of the radiator support? I need to look to see if there are any holes. I also just discovered that I am missing the horn wire clips where it runs across the front of the radiator.- Top
Hi Dale, the clip pushes in on its side onto the edge of the radiator support, there are no holes for it. Phil 8063Phil, thanks for catching my missing clip. It must have been omitted when someone a few years ago replaced the radiator support. I just want to clarify, this clip is on the front side of the radiator support? I need to look to see if there are any holes. I also just discovered that I am missing the horn wire clips where it runs across the front of the radiator.- Top
