If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
How do I lube the gears in the drive unit where the tach cable hooks up?
What kind of lube do I use?
Thanks guys.
Mike -
I used Lubriplate "A" (white lithium grease) in all of my C1 tach drive gearboxes, never had a problem. Remove the box from the generator, take it apart, clean the parts, lube, put it back together, and re-install.
