If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Ok I know it does not have the partial grove on the bottom but I'm not positive all did. it has it's 093 tag dated 5 K 18. It was removed from an original 66 425 HP car 25 years ago. Regardless if it's a real BB dist. Whats it worth?? Customer sent it to me as part of a payment and I want to make sure he gets a fair real world price.
One point that a potential buyer might notice; the magnet type is 2nd design, with the lips on each side of the 3 hold-down screws (see pic of early type [no lips] at right -- at least until late Feb 1968) versus later type.
Wayne, thanks for the info I was unaware of the magneto difference. I did know that the original magneto wires were different than laters (specifically the green tracer as opposed to a solid green wire).
Wayne, thanks for the info I was unaware of the magneto difference. I did know that the original magneto wires were different than laters (specifically the green tracer as opposed to a solid green wire)....
Rich -- yes, the solid green (separate, not siamesed) wire must have begun sometime in mid-70s or even the '80s. See pic below of stationary pole pieces for '64-5 TI only [the difference is in the center plate sleeve] -- rare because of the part #. Magnets have the lips but wires still have green tracers. The type of packaging tells me that these are from the '70s. I have original K66 distribs with no lips as late as 9D14, and the earliest with lips is a 0J3 1112038 (w/the green tracer). I have another service 1111157 distrib 4K9 (1974) and it still has the tracer.
