If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Phil, I'd appreciate it if you could give it a look see. I guess I should have added that I've looked everwhere on mine and can't find anything. I've had it in the bright daylight, in the dark - back lit and front lit and everything inbetween. I'm just curious as to what it might indicate.
