If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
My 62 (#2272) was built on or about November 3rd 1961. My question is regarding the correct date code for the expansion tank. Would this car use a November date (L) on the expansion tank or is September (J) more in line ? Also is there a good source for the dished hex head bolts with the "U" or "E" marking that attach the hood support to the hood?
Thanks Rich
