If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
does someone have a picture or maybe tell me how the carpet stops off at the rear vents, under the rear deck? the carpet is hemmed so i don't think it goes under the vent. thanks
