C1 Front Suspension - Bolt Direction (59) - NCRS Discussion Boards
  • John F.
    • January 1, 2000
    • 155
    Do all 16 bolts on the cross member go in the down direction?
    How about the 4 on the lower A Arm shaft? do they go up or down?
  • Jerry W.
    • January 27, 2009
    • 588
    Re: C1 Front Suspension - Bolt Direction (59)
    frame to rail...outboard bolts....down
    frame to rail...inboard bolts up
    a-arm shaft bolts down
    62 pic attached
    • Dan P.
      • December 1, 1990
      • 683
      is the bolt direction the same on a 57
      • Mike M.
        • May 31, 1974
        • 8408
        controversial. not sure anyone knows for certain but i've always had the head of the bolts facing mother earth.mike
        • Joe E.
          • April 1, 1985
          • 77
          I just took apart a July 56 Corvette and it had all the bolts going down.
          I did a 62 last year and they were inside up and outside down.
          Both of these cars were original and had never been apart. I have done both 59 and 58 and they were like the picture shows with inside up and outside down.
          • Don Y.
            • July 31, 2000
            • 166
            If I recall correctly from '58 on the bolt orientation was different from the '56 & '57 due to the bumper bracket location points on the frame. That is where the "inboard one way, outboard the other" comes from.
            • Tom P.
              • April 1, 1980
              • 1826
              62 pic attached
              Jerry,
              That is a beautiful frontend, but my question is, IF, as it is understood, the chassis received black paint all over BEFORE body drop, wouldn't ALL the fasteners AND inspection paint markings be completely blacked out?
              On a "supposedly correctly" restored car, the inspection paint markings look very nice and the brand new fasteners also look great, but as I understand, none of this would be seen if covered with black chassis paint.
              And the second part of that question is, if everything was covered with chassis black during the trip down the assembly line, is there a deduct for exposed new fasteners and inspection paint markings?
              Just curious for my own information.
              • Jerry W.
                • January 27, 2009
                • 588
                Tom....No Black Out ?....The car will be for GO....not for SHOW....Just couldn't see painting all that nice new stuff with Black Out
                • Tom P.
                  • April 1, 1980
                  • 1826
                  Excellent! I like that!
                  • Troy P.
                    • February 1, 1989
                    • 1284
                    My understanding from studying assembly line photos is that the bare frame arrived on the line upside down and it was already painted. That's why the frame stencil is upside down. Then the front end assembly, which was also already painted, was dropped on and bolted in, upside down. So from that sequence it would seem the bolts would not be painted.
                    Also the assembler could put the bolts in from either direction. But logic would dictate that he would do whatever is easiest as far as what direction was chosen. Also different assemblers could well have a different feeling about what was easiest for him in terms of getting the bolt, washers, nuts and impact wrench on. That may have even varied depending on him being right or left handed. So I doubt there is a definitive answer. Best to take notes during disassembly and just return it the way you found it.
                    • Terry B.
                      • December 6, 2010
                      • 73
                      If it matters my "untouched" 62 is inside up outside down.
                      • Edward M.
                        • November 1, 1985
                        • 1922
                        My 56, #2117, has never been apart. All of the frame to front suspension bolts are pointed down.
                        • Chris H.
                          • April 30, 1990
                          • 817
                          Here are photos of mine before disassembly. Not sure though if they were ever touched before but I doubt it.
                          • Chris H.
                            • April 30, 1990
                            • 817
                            Four more pics.
                            • Chris H.
                              • April 30, 1990
                              • 817
                              one last one
