I'm working on my 67 air contd. engine compartment that I started four years ago and just now starting to assemble things. (forgotten so much)
the right fender tub has been replaced and I'm trying to locate the correct placement of the holes for the hose retainers. In the aim on page UPC C60 D3 the location of heater hose retainer looks pretty straight forward, but the front retainer for the AC hoses, UPC C60 D7 seems more complex. I only want to drill once! I was going to use the dimples in the tub as a drilling point until I saw the diagram . should I follow the measurements as described in the Aim? seems like the dimples were put there for a drill marker.
Thanks for any help, Craig
327, 350hp
also can't seem to find the placement of the AC label on the evaporator box. a photo if you will.
327, 350hp
